TwinTurbo.NET: Nissan 300ZX forum - Re: Need help in BrEFI replacement? tip:
Subject Re: Need help in BrEFI replacement? tip:
Posted by CoHPhasor on February 19, 2011 at 12:25 AM
  This message has been viewed 276 times.
In Reply To Need help in Branson Mo posted by Sketch on February 18, 2011 at 09:12 PM
Message If you're doing it engine-in, don't screw with trying to wrestle it in, or bending/enlarging the hole in the firewall.
There is a bracket in under the dash that is held down by 2 nuts.
This bracket is what gets in the way - REMOVE IT.
Many here have de-pinned their harness connector through the years, or bent the opening, but you can simply dremel the metal bracket and be done with it.
Sitting in the engine bay this weekend, I didn't realize that, and I bent/enlarged the opening.
Since then, I've seen pics of the dremel'ed bracket and I would definitely have opted for that.
